Today I found the zinc anode ring that goes behind the prop loose. One bolt was missing and the other was loose and damaged. Looks like they came loose on the last run. The anode is damaged and will be replaced. I would like to get some bolts that are just a bit longer than the P/N 941809 original bolts. Does anyone have the correct size (diameter and threads per inch/MM. The one bolt I have left has the threads so far gone they can't be measured.
I did check the bolt holes in the case and they do have threads and seem to be OK.
Many thanks in advance!!!
