Re: Bolt torque 76 OMC outdrive water pump 1/2" bolts
With a bit of sealant on the threads those bolds are good at that touque, the most of the load applied is when you turn your outdrive port or starboard. When you have to change your pump impeller we dont want to crank them any harder the necessary to loosen when taking them out. Thats what I torqued mine too.
