Re: bolt stuck in block.. tap & die?
I
hate easyouts. If I were in charge of it, their inventor would not enjoy their afterlife.<br /><br />If there's anything left of the bolt to grip with a set of vice grips, you should begin by trying to wind them out. If you don't have one already, invest in a propane torch - or better yet a propylene or mapp brazing torch. Practice trying to melt some scrap aluminum with it first - it'll give you a good idea on how much you can heat something before it melts. HINT: it's almost impossible to melt the larger aluminum castings with any of the above mentioned torches.<br />Between heat and penetrating oil, you can remove any fastener as long as your careful - provided you can get a grip on it. Needless to say, you're gonna need vice grip brand vice grips, or some supurb knockoff, to grab it well enough.<br /><br />If your broken flush, what I do is carefuly file the top as flat as possible, punch the exact centre of the bolt stud, and drill incrementally larger holes until there's just the thread left behind. Then I pick out the first bit of thread (sometimes I get lucky here and the whole thread comes out like a spring), and tap the hole out with the exact size tap as the original bolt. Rather than cutting a new thread, the tap just cleans out the old thread.<br /><br />Paitence is key. If it's beating you, walk away from it and come back another time. It's easy to go from bad to worse.<br /><br />...quitely grumbling about people who profit from the desperate. No good good for nothins who kick a guy while he's down...
