stoked not
Thread starter- Joined
- Jul 20, 2001
- 143
I'm having two problems but I'll only talk about one on this post. 1992 Johnson 225 HP is bogging when I run. She to idles fine. She will drop RPM's when I run the throttle up to 5 MPH then it speeds back up. She does it at all speeds. Not sure if I have a fuel problem or electric problem. Here's what I have done so far.<br /><br /> When she bogg's I pump the primer ball, push the choke, no change. Ball feels good<br />checked for spark in the driveway while on the ear muffs, all six have spark.<br /><br />Installed a new primer ball and water seperator filter. No change.<br /><br />Vent on gas tank appears to be clear.<br />Good compression on all six.<br /><br />Do I have a fuel, electric, or timing problem?
