chadchurchill
- Aug 24, 2003
- 59
The past few times I've been out my 1986 75hp mercury at times sounds like it is about to stall and occasionally does, but usually would start running ok after a minute or two, or after I give the bulb a few pumps. Today I was out and it ran fine for a while and then started sounding like it was going to stall again. If I tried giving it more gas, it would stall unless I pulled back a bit on the throttle. Ran like this for about 30 minutes going about 8 mph until i gave the bulb a few pumps and it ran fine at all speeds for the 15 minutes it took to get back to the ramp. <br /><br />Before my motor broke down last summer it never did this. Since last summer this is what I've done to the engine: new stator, switchbox, fuel pump diaphragm, and installed a water separating filter. Do you think doing any of those would cause the problem I'm having now?<br /><br />Thank you for any input.
