jonny rotten
- Jan 8, 2012
- 345
4.3 2 bbl electric choke
On muffs
Stays running at higher RPM's and sounds fairly smooth
At idle it stalls when cold BUT if I close the butterfly to almost closed it revs up. I can sorta control the RPM's with the butterfly.
Seems to stay running better at idle when warm but still not good enough that I trust it enough to test in the water
I thought it could be choke issue
The choke closes all the way when cold when I pump the throttle to reset it .
Does that mean the electronic choke is working correctly?
I "think" it opens to full open almost immediately on a 75 degree day but I'll watch it next time.
Cleaned inline filter at carb
New fuel pump last week
New water separator
Cap and rotor look pretty much new
Thought I might have bad gas from last year so I disconnected the fuel line at the water separator and filled up a water bottle and it sucks up the gas almost to quick so it's getting plenty of gas. It runs the same as with the old gas
Could it be a vacuum leak somewhere?
I thought I read with electronic choke vacuum leaks won't have an effect but could be wrong?
Was working fine when I put it away last year so it makes sense in 6 months the gas gummed the carb enough to effect the running condition but still run. Ran seafoam in it last year before putting it away but maybe not enough?
Anything I can do or check before a carb rebuild that I'd rather not do in the middle of the summer.....but will if I need to ASAP to get in the water
On muffs
New water separator
