hullofalottatrouble
- Jul 16, 2005
- 306
1982 merc 260 5.7 350.. reman rochester qjet carb.. comp is good all around..
got the reman fired up.. got it to correct idle 700 rpm.. and got timing set dead on last night.. vacuum at 18 and steady
noticed as i perhaps too gradually throttled up the engine would bog down and hesitate around 900rpm then would jump up to about 1200 RPM and run strong at that point..
the accel pump is working.. when i pump the throttle it shots 2 strong streams of fuel.. thou i have to say i dont know what if any fuel it pumps during my gradual throttle up..
the boat is on the trailer without the drive attached..
i didnt try to mess around with the carb to fix the problem.. it got to be too late so i packed it in for the night..
i am wondering if this is just really bad carb adjustments on my part? this perhaps a choke issue? bad idle settings?
thanks..
thanks..
