caravelle 350 captain
- Oct 10, 2017
- 2
i have a 2007 caravelle 237 ls, with a 350 mercruise.
the boat goes into forward just fine
one out of every 10 times i try the motor will engage reverse.
i opened the back and watched the shifter cable as i tried reverse and it would move a little bit but not enough to go into reverse.
it would just move little bit then it would be like i am in neutral and the engine just revs up.
it moves alittle forward then goes back into neutral. it starts to engage then pops back into neutral with the throttle handle in reverse but it is in neutral on the motor.
do i need a new shifter cable or does my problem lie else where.
thank you.
thank you.
