boat wiring questions
waterbill
I bought a used boat. The wiring is a mess. In the stern, the battery box has lots of ground wires twisted together and electrical-taped, along with several grounds stacked onto the battery's negative terminal. On the console is a fairly ok fuse/switch panel handling the positive<br />side. There are these long buss bars available at marine supply stores which can handle many common negative wires. My questions are A)are these a good remedy for this situation, and B)would this negative buss bar be best located in the battery box?
JB
Re: boat wiring questions
Moving to Boat Questions.
