Re: Boat turns rt. now, ? skeg adjustment
Thx for all those quick replies.
I had mentioned in my first post that maybe the mechanic tightened it down to the right cause that's where it was.
It does not have that much travel in either direction anyway. It's not stuck. I can feel it hit it's stop in either direction. The bolt is on the top of the cav plate.
I know it makes sense if the boat is steering to the right, then the skeg should be moved towards the right to compensate for steering right. I think of it as a little rudder.
But what threw me was when we got home it already was tightened down to the right.
When we first got the boat that skeg's bolt was loose and the skeg was just flappin around.
So I took it out myself with a wrench and adjusted it last season and had it steering perfect. But I couldn't remember which way I adjusted it because I seem to think it was opposite to correct it because I had to do it twice where I would have started off with it on the right.
I thought I'd ask here because maybe it had more to do with correcting the boat's steering as to the rotation of the prop.
I asked because I did not want to drive 40 miles round trip to test it in the water. It's not my boat! You can't test it in a tank for this.
As another poster has said . . . if that skeg was to the right than I have other issues.
Last season it ran perfectly straight after I adjusted it (I should have marked it). I did not make any changes since last season but the Mechanic may have changed the position of the tilt pin?
When we were doing about 20 mph I looked backv and there was a slow trip coming down from the top of the transom under the splash catcher. That catcher does not leak it was dripping down from the wood under the aluminum that caps off the wood in the transom.
So I looked back at the spray off the O/B and it was very heavy spraying forward against the transom probably getting through some accessory holes or the bolts holding the o/b on the boat. I moved the tilt pin towards the transom one hole. It was around the middle of the 5 holes before I did this. The dripping stopped. Boat handled OK after I moved the tilt pin but I was not driving on the way out. I took over on the way back and noticed it was pulling to the right. In the center hole it may not have been pulling but it was dripping. There was 3 inches of water in the bilge before we turned the pump on. But that might have been from cleaning and hosing down all the rugs a few days ago and water probably was puddling in between the ribs and was being blown back at 20 mph.
I know what the issue is going to be just because of all that spray. I know it's going to be that the O/B was installed too low by the dealer.
I'm going into the garage and take some pics.
Update: Sad, it's exactly what I thought it was going to be:
This is is where I brought it home after pulling pin in closer to transom, leaked stop but still heavy back spray against transom.
Th
Pin moved back to center hole position where we used it last year:
Straight edge held under cav plate:
There is about a 4 inch space there from the bottom of the boat
. No holes to change though. It's a clamp on top resting on the transom. Two small bolts outside at bottom of bracket.
I don't want to raise it and find we have less control but I'll have to take the two bolts out and bring different sizes of wood pieces down to the river and place them under the clamp to move it up so the cav plate closer to even with the bottom of the boat. While Im test running it without those bolts in place though if I go in reverse to hard it could be bye bye O/B
I had to move my own O/B up a hole to cut out the back spray when I bought it. It's amazing how little these dealers know or put inept mechanics when mounting O/B's to a new rig. This one is 11 years old. My 2007 was mounted off too so it looks like as the years pass things don't get any better.
Looks to me that they just hung the clamp over the transom and bolted it down. Or the dealer thought the cav plate was those two upper fins
because one of those fins is even with the bottom of the boat.
It's a 20 inch transom, but that O/B hanging that low might mean the O/B is a long length model.
Oipinions welcome before I start drill'in holes in my Daughter's boat?
Update: Damn, I checked checked the O/B's model plate. Says 1999 25 EL
That's the problem, I'm sure that EL stands for extra long! The transom measures 20 inches.
Other choice now is to find a reducing the shaft type kit or a used lower medium length unit.
I might just say screw it and get her an adjustable jack plate? I already invested $700 into it for new carb and impeller and it runs excellent.
I might try and talk her into trading it on Craigslist and getting a 25 4 stroke new or used. I don't like the idea of cranking this EL up too high and maybe throwing off the center of gravity on this small 14.5 foot aluminum.
I can't believe I missed this EL mounted on this boat. She bought it off Craigslist and sent me down to CT to pick it up last season for her. I was so excited at the conditon this 11 year old boat when I saw it that I missed the fact that it had an EL shaft O/B on it.
I figured if the O/B was not great, the boat was still perfect and we could sell the o/b on CL and get her a 4 stroke. I wish I knew it was an EL before I invested the $700 into it.
