Boat trailer wiring with surge brakes, whats the blue wire for ?
WHALER78
06 Continental ..My trailer has disk brakes and is a surge type. What does the blue wire do. Where does it get hooked up. Its not electronic brakes that require a unit under the dash like big travel trailer. Thanks, WHALER78
JB
Re: Boat trailer wiring with surge brakes, whats the blue wire for ?
Could it be the back-up light wire to lock out the surge brake when backing??
nlain
What JB said, as to where it should hook up, look for a solenoid in the brake line, probably in the tongue and near the master cyl.
triumphrick
That is exactly what the blue wire is for. You can test it by reading it when the back up lights come on..should be 12v...One side of that solenoid is grounded, usually by the mounting bolts..the blue wire connection is so the solenoid wont let fluid past it when backing..not a problem on a flat or descending grade, but almost impossible on anything uphill.
All of the connections and layout can be viewed once that cover is removed..
jhebert
Ensign
For a good reference and summary of trailer wiring conventions for 4-position flat, 5-position flat, and 7-position round trailer-vehicle wiring, see my article at
http://continuouswave.com/whaler/reference/7poleTrailerWiring.html
If you have surge brakes, there is no proportional control of the brakes by electrical means. However, some boat trailer brake systems are rigged to defeat the surge brake actuator by use of an electric solenoid valve which is rigged to spoil the brake pressure. This is typically rigged so as to spoil the brake actuator when the tow vehicle goes into reverse, and usually takes its signal from the tow vehicle's back up lamp circuit. This allows the trailer to be backed up, even though the surge actuator is trying to apply brake action.
G
Guest
Guest
Yes it is for the back up lite switch as I have just done mine with new coupler and that is what the blue wire is for.
