TroutFisher87
- Oct 6, 2013
- 2
I'm sure everyone can relate to faulty boat trailer lights, and I'm having some difficulty troubleshooting mine. I ran my green wire to my right turn signal light, the yellow to the left turn signal, and a brown to the left tail light. I used a jumper wire to get to the right tail light. I connected the white ground wire back to the tongue of the trailer about 2' from the wiring harness.
The issue I'm having sounds like a ground issue, but I'm not sure. Only one of the tail lights is working, the left turn signal works when I turn on the left blinker; however, it continues flashing when I use my right blinker as well. The right turn signal does not work at all. The left brake light works well, but the right brake light does not work or is really dim.
I've tried the boat lights on 3 different trucks to make sure it wasn't just my truck and I'm getting the same results. Also, I've tested the trailer lights by hooking directly to a battery (the ground to the negative post and the yellow, brown, and green to the positive), and the lights worked perfect when I tested each of them individually. I thought it might be that the grounding through the trailer was not correct, so I've ran ground wires from the post on each light back to the white wire ground on the trailer. In this way, the lights are grounded directly from the tail lights back to the white wire coming out of the wiring harness. I'm still getting the same results, however.
Does anyone have any clue as to what the issue may be?
Thanks.
Thanks.
