Re: Boat to low in water and motor will not perform good.
As Incoop said it is probably water in the tubes, easiest way to tell is to pull the boat and once it is on the trailer have someone drive forward a few feet then stop suddenly then put your ear on the tube, if there is water you will be able to hear it slosh around.
Aside from that all you can do is to shift some weight forward like moving the gas, both tanks full are about 170lbs, not alot but it has to help, also whenn you ar underway have people sit forward to spread the weight better.
Are these 25'' or 23'' tubes?
