I have a 24 ft center console on a magic tilt trailer. When I put the boat in the water off the trailer on a steep ramp water comes over the transom in the motor cut out. If I move the winch back on the trailer it does not do this. But then the boat is so far back on the trailer the transom saver does not work. Am I backing the trailer too far or not far enough into the water to launch and retrieve maybe? Is there a certain way to know how far to back the trailer in? The tongue weight is good either way I put the winch. The problem is I cannot put the winch in between where I am because the trailer frame is in the way at that point.
