Hi all, I was out with my Bayliner Capri 2001 boat running at full throttle and the propulsion just completely stopped I heard some rattling noise. The motor runs and starts fine but it will not engage in forward or reverse. I brought it home look at the engine the shift cables all seem to be fine. And then I saw that the drive lube reservoir was completely empty. I assume I am screwed because there is no lube oil in the lower unit. Can anyone confirm or give any advice.
