Ok I got my boat running today and was running to warm up the oil for an oil change. While it was running and since I just had the outdrive off to change the water pump and lube the u-joints, I decided to try to shift it into gear.
This is where the problem arose, the boat stalled every time I tried to shift it into forward gear. Does this mean my lower shift cable needs to be replaced or are there other things I should look for.
What has me confused is that in the adult only section it states this;
"The system is NOT designed to work when putting the drive into gear, or when the boat is out of the water and on muffs"
Any help is greatly appreciated
Thanks in advance,
Kyle
Thanks in advance,
Kyle
