I have a 1996 Stratos 285 Pro-V with a 150 hp johnson fast strike. I bought it used and have been having problems getting it to run right. My tach is still not working but I had the engine checked on a dyno and it is producing plenty of power (more than 150 hp). Here is my problem:<br /><br />When I run wide open, it seems too flat. The spray starts just behind my seat. When I let up on the throttle (foot-controlled), the bow lifts and the boat jumps up on the last pad. When I add gas, it drops back down.<br /><br />With full gas tanks and two people (I weigh about 200 and my partner weighs 300 pounds), it will run about 52-53 GPS mph. With just me, it will run about 54. The factory (and others) say this boat should run about 62-64. <br /><br />I think, that if I can keep it on the last pad, it will speed up. I have a 10" jack-plate and have moved the motor up as high as it will go (26 pounds of water pressure).<br /><br />I know that I have some nicks (not too bad) on the prop so that may be part of the problem. I have been told that a "hook" in the hull may cause this type of problem. <br /><br />How do I find out if I have a hook? I sent my old prop to be reworked and it looked beautiful when it came back but a friend showed me that it was "out-of-round" - that is, it wobbled a small amount when it turned. (the shaft did not wobble). I would like to get the one that came on the boat rebuilt, but don't want it to come back the same way.<br /><br />Suggestions? Thanks!
