I have a 1963 18' Seacraft that I am 'revitalizing' (not quite a complete restoration). I plan on replacing the floor, and also working on the outboard engine. But, first I at least need enough wiring to crank the motor. It is setup now to have the battery in the back of the boat, and the ignition switch is in the front with the steering wheel. That stuff seems to work fine,<br />I was able to crank the motor a little bit with a battery charger hooked up.<br /><br />I want to re-wire pretty much everything. There is an Evinrude electrical box, looks like it has a starter solenoid in it. I am thinking of using one, or maybe two lead-acid batteries, simply due to cost. Separate batteries for starting and for running accessories. <br /><br />For accessories, I'm thinking about getting a 6 or 8 circuit fuse panel/switch box. The previous owner had several switches and fuse locations, it is a rat's nest. I'd like to have a circuit for AM/FM radio, CB radio, interior lights, boat lights, cigarette lighter, and maybe someday add VHF and a bilge pump.<br /><br />I'm looking for suggestions, or maybe if there are some webpages showing what people have done when re-wiring these types of boats. I am confident enough to do automotive wiring, and can use a solder gun and heatshrink tubing. <br /><br />any pointers or website recommendations would be appreciated, thanks<br /><br />Mark
