I've had a 17' Smokercraft with 125 HP Mercury for about a year now, and I just started noticing last week that the boat pulls slightly to the left when trimmed up while cruising. When going straight with trim down, I can keep it very straight by keeping the steering wheel straight. At WOT, I have to turn the wheel somewhere between 60 and 90 degrees to the right to keep it straight.
Could this be something that was recently caused by a bent skeg, or a bend in the prop? The prop looks ok, but perhaps there is something I'm missing? I've tried adjusting the steel-colored trim tab on the anti-cav plate to compensate, but it doesn't seem to have any effect at high speeds.
Could the motor not be straight on the boat? Using my eyes and a few quick measurements, it certainly isn't way off in either direction.
Is this something that is just inherant with the boat, and I shouldn't worry about it? It doesn't seem to be unsafe, by any means.
Thanks!
Thanks!
