redr2redr2
- Aug 12, 2018
- 11
Morning folks. I have been searching and reading posts and need some expert advice. Lots of threads on boats pulling to one direction, trim tabs, etc but this one may be unique.....My boat wants to pull hard to the right:
My boat is a Malibu 162 (16 foot runabout). I have a '98 Honda 75 outboard. I bought it was a nearly seized up pivot and last year I installed a new pivot and a standard new cable/helm. I did not go with one of the torque lock helms (should have) as quite frankly I wanted buttery smooth steering after fighting with it all seized up so bad
Anyway, pulled the motor off to do the install and got it all back on. Boat bulls very hard to the right now if I let go of wheel. Dangerously so. It may have been like that with the seized pivot but there would have been no way to tell. I have adjusted the trim tab in the right direction (rear facing the right) all the way to one side (far as it goes) to no effect. The boat drives straight but if I let go of the wheel it dangerous.
2 Q's: If its 'crooked' in the transom mounting holes would it cause this? (ie. not sitting a 180 degrees pararllel with the ground/water?)
Is it mounted too high??? In the photo its trimmed all the way down. This is the way I nearly always use it in the water. I can trim it up slight;y but more than a little causes the front end to bounce a bit too much....so I run it trimmed right down 98% of the time.
thanks!!
thanks!!
