boat problems
mav1973
hello i just got my fist boat 14ft alumacraft with a 1974 9.9 evinrude need to know what oil mix and what kind (nomal 2 cycle) will this motor move this boat well no whight in about 350 total alo want to change oil has 2 regular ***** and 2 philups? which ones is the drane/fill what kind of oil for that also have couple of revits linking 5 total 2 came out the others leak drop here there what can i do put nut/bolt with little rubber washer dont want to scrap boat but dont want to put lot of money in to it thanks
rterrian
Re: boat problems
First off, the small bolts and nuts will work in place of the rivits. Only don't use rubber washers, use a sealent and tighten the nuts tight as you can. As far as oil in the fuel mix it should work well with 50 to 1 mix after some use. But start with a 32 to 1 mix until you get some hours on it (at least 3 gals. of fuel). That engine will move that boat at about 12 to 14 mph. I would prefer a bigger engine but that will work. Just stay out of rough water as you will not have a lot of power there. As far as changing oil in the lower unit, its the screws with the regular screw driver slot. One is down near the bottom and one is about 7 or 8 inches straight above that one. Remove both and catch old oil in a small pan so you can examine it. It should appear dark brown or almost black. If it is milky white that is a sign of water getting in and you will have to find the problem. If you find that get back to this forum for help. The oil that goes back in is a speical outboard gear lube and it comes in a plastic tube, can be purchased at most parts stores or Wal-Mart, K-Mart or other stores. To install it just cut off a small part of the tube and leave both screws out, insert tip of tube into the bottom screw hole and squeeze the tube and force oil in until you can see it seeping out the top hole. At that point install screw in top hole with new gasket. then you can have the bottom screw ready with new gasket and quickley remove tube and install bottom screw. Tighten both screws as tight as you can get them so as to keep water out. Wipe off excess oil and check for leaks. If oil can get out, water can get in. You should see if you can locate a manual for that engine. It will help you alot. Posibly the library.
steelespike
Re: boat problems
Mix is 50:1 tcw3 rated oil.<br /> Large slotted flat head screws are drain and vent.Use outboard lower unit lube.<br /> 9.9 should move the boat fairly well if its not loaded down with a lot of usless weight.With 350 lbs I would guess 18-20 mph.Fill through the<br />drain hole until it comes out the vent.<br /> If you can reach both ends of the rivets get a friend and 2 hammers,hold a hammer on one end and rap on the other with care untill it seems tight.<br /> You can replace a few with bolts and nuts.<br /> Some dont reccomend too many bolts because they dont flex like a rivet will.<br />Im not saying im right but I wouldnt use washers of any kind.Use stainless bolts and jam nuts with silicone or goop or other sealer.<br /> I have some 40+ year old bolt repairs on my 47<br />year old Crestliner utility.
Solittle
Re: boat problems
mav - It is a great motor. I have a 75 on a 13'. Runs well (on plane) with two aboard.
mav1973
Re: boat problems
thanks alot guys im going to try this with the next couple of days cant wait till its on the water with the nuts /bolts should last pretty long i hope all the revits are on the bottom in the back close to seat next 2 are under the second seat hope it works i have locking nuts i'll use wish me luck thanks again hope to see ya on the water soon!!
mav1973
Re: boat problems
well done all that the mottor wont start should i take it to the shop if so will it be alot of money for them to tell me whats wrong
22WRF
Re: boat problems
Boat US and West Marine sell watertight Pop Rivets
mav1973
Re: boat problems
fixed the boat now on the motor getting ready to call marine shop cant aford it pocket little dry u know
