I have a 18 ft. 2000 Maxum 1800 SR with Mercruiser 135 HP engine with only 117 hrs. I've had the boat for 3 weeks and everything was fine until this past Sunday. I had it running and everything was good except starting was always difficult at times. On Sunday just didnt start at all. The engine turns (it makes the noise but wont catch) and all the connectors are good, but I replaced the battery to make sure, so I may have to check the wires again. Am I missing anything? <br /><br />I have checked the starter solenoid and everything seems to be connected properly. Only thing I did was look at the wire to see if its was clean and the center wire was a little bit dirty, so I attempted to clean it and start it back up with no avail. I even took out one of the spark plugs and have gotten a replacement. I have not put it on since the boat is on the lake currently. If its not the spark plug what else is it that is not making it fire up?<br /><br />Thanks,
