I'm at a loss. I have 2003 Mercury 50hp 2 stroke motor. My problem is when I idle or trolling at near idle speed i loose fuel pressure. If i pump the bulb i'm good to keep going. If i'm at WOT i'm good to go. I'm going to list everything i have done. Any help is appreciated!!!
Last fall i rebuilt the engine top to bottom all OEM parts. Runs great.
cleaned carbs (soaked, sprayed then air blow out)
just rebuilt them again last week (hoping this was the issue. NOT!!!!
replace line w/ bulb (1st one would collapse and not open till next day) replaced it again now losing pressure. I can pump it and leave it sitting it doesn't loose pressure.
I have replaced, pick up tube, check valve on tank, tried cracking the fuel cap, all fuel lines on motor, new quick connecter for fuel line both sets, replaced the T valve coming from the solenoid, i have rebuilt the fuel pump twice now, and anything simple you can think of i have checked or replaced.
Now sometimes when i pump the bulb as tight as it will go i can hear a slight squeal sound. not always but sometimes idk if thats what causing to loose the vacum and loose pressure. I have checked the floats to the book and they are within specs (not sure if i should adjust them anyways????
I'm out of ideas and ready to beat my head against the wall.
I have read about sycronizing the carbs? i think this is more a 4 stroke thing. not sure.
Also does the fuel solenoid (not sure exact name but it helps to crank boat when you push key in) be bad and causing the loss of vacuum? When i push key it clicks and if its warmed up and i push key it starts to bog down like its being flooded so it seems its working. But i read somewhere it could be working but losing vacum. Can you rebuild, or clean this item?
Please help!!!!!!!
Please help!!!!!!!
