papafrancisco
- Jul 22, 2004
- 39
I recently removed the paint from my Evinrude motor down to the gel coat. I painted using Tempo zinc chromate and with four coats of Tempo marine paint. I let it dry for a day and than sanded using 800, 1000, 1500, & 2000 grit wet/dry paper. The surface is smooth. Someone mentioned I should clear coat. If so is the surface too slick? Should I re-sand using 800 paper? Should I clear coat at all? Any thoughts will be appreciated. Thanks
