I have a 85 Sea Ray Weekender with a 260v8
Here is the problem. I have a water leak coming in below the exhaust Y pipe. I have replaced all the Bellows on the transom and Yesterday Pulled the motor and removed the Y pipe and Replaced the Gasket. It did not seem all that bad. I put the boat in today and lo and behold water is still coming in below the Y pipe.I cannot tell without a camera exactly where but it is running in on the bottom of the transom assembly. Any Ideas would be greatly appreciated. On Monday I will tilt the boat up and put some water in the bilge and look for a leak somewhere. The Exhaust looked in good condition and it does not leak with mufffs on it. The amount of water coming in is quite a good stream I would say like a stream from a good size straw. Way more than if the exhaust gasket was compromised. I am out of ideas at this point. How do the trim hoses connect to the transom and could water come in that way? Please Help......................
Thanks
Have a great 4th I'll be drowning my sorrows at home not on the lake
Thanks
