I have a 1989 50hp force. The title says 1989 but the serial number indicates 1988. It is on a 24' heavy pontoon boat. When I take off from idle and go full throtle the engine lags until the boat starts to get a little speed and then the motor will go full throtle. Sometimes the engine will die while it is lagging if it takes to long to get the speed going. The carb was adjusted. I tried pumping the bulb on the fuel line. Nothing helps. One person told me i need a torque prop and not a speed prop. If this is the case what size prop do i need (what pitch). One more thing. when the motor is idling the motor will have a knock ever once in a while but not when it is open throtle. Any help whould be great.
