Re: Boat has a Hydrofoil from previous owner, should I remove???
Honestly, the thing planes extremely fast. And I can stay on plane at incredibly low speeds. I would say I can actually be on plane in less than 5 seconds, no lie, no exaggeration... Maybe even a second less than that. It literally lifts on plane right out of the hole when the motor is trimmed down. Most bass boats stand up in the front when they launch, if I want to do that I have to make this thing do that by trimming the motor up. But the bad thing is that motor wasn't the factory motor so moving it down isn't really an option the way it's setup. Moving it up I have some room, but not down. I did post up in the prop section too, but do you think a prop change would help? Like going to a 4 blade from a 3?
props arent your problem....and neither is the whale tail.......you are running a short shaft motor on a long shaft boat......if you look at the keel in pic 2.....see the line of the hull under the drain plug?....now....follow that line to the prop......the prop is half way out of the water the anti vent plate is supposed to be even with the lowest part of the keel.....what that means, is your prop is ventelating....(getting air in where the water is supposed to be) the whale tail is acting like a anti venetelation plate...(the normal plate just above the prop on the out drive.....this si to keep water flowing around the prop so you push water and not air. this is also why you only have a 45 mph top end..
a 19 foot bayliner with a 4 cyl 120 hp will hit 50. (dont get me wrong.....45 is good...but that is a bass boat with a big honkin 6 cyl hangin off the back.)
however......it does look like you have a big alum jack plate on the boat....i would check that thing out and see if the motor can be lowered any more. you will have a totally different boat. the boat will drive the way its supposed to...and your top end will be super. your prop isnt biting water...its biting air.
if you take off the whale tail now.....i think you will find you will have allmost no performance....you will rev the motor, and it will just spray water for 20 feet out the back.
tho it is true that some drives are made for super performance only being half way in the water.....(surface drives) they spin a lot higher rpms than you do and they are made for different hulls than you have.
some of our prop gods will be in tomm morning....
(i am more of a hull tech)....but the real problem is obvious
