Boat dying at idle when cold and when put in gear sneezing and pulsing at high rpms
Grunt1212
So i have a 1990 stratos 289 fs it has a johnson 150gt. Had the timer pack and power pack replaced last yea . Ran great 2 weeks ago full power no.issues until i went to re trailer then it wanted to keep dying when i was trying to load on traile . And half way through the day i started to get warning alarm at 4500 or higher no issues. Vro pump is disconnected along with the wiring. Went home changed fuel filter and fuel line and bulb (3/8) ran great out of water. I also use sea foam at almost every fill up. Get to the ozarks this week cold start was ok ran great all day tuesday, wed morning after it was warm it started sneezing a bit and would die when i put in gear unless i gave it some decent throttle then would be fine. By mid day it was sputtering a bit at 4500 and above then would go full power and would be fine until next take off. Then the boat ramp issue again thursday plus on the way to the ramp it was acting like it was out of fuel. Just looking for suggestions. Fuel pump or what. When they diagnosed it last year they said the carbs looked fine and keep up with the sea foam. If it is possibly the fuel pump can which one do i buy that doesnt have the vro thanks
Have you done a compression test ???-----Post your numbers.-----It is the first step to take in trouble shooting this motor !
