POPS PLAYPEN
- Jun 4, 2007
- 22
I Have A 1992 Searay Sundancer 270, 7.4 Engine 330hp Boat Has 410 Hours On It. Still Looks And Runs Like New. Very Well Maintained. The Problem Is I Have To Run At 3000 Rpms To Keep The Boat On Plane. 2900 Starts To Fall Back. Is This The Correct Plane Rpms?boat Has Been In The Water For 16 Yrs Except To Come Out For Maintanence Then Right Back In Water Which Is Fresh By The Way. I Pulled The Boat Out This Weekend For Service And The Prop Was Corroded On The Outer Edges, To The Point Some Is Missing And Very Thin. It Is A Three Blade Aluminum (i Guess Original). Don't Know Pitch Or Diameter. I Am Thinking Of Changing To A 4 Or 5 Blade Ss Prop. Will This Aid In Keeping The Boat On Plane At Lower Rpms? And If So What Would Be A Good Pitch To Go With? The Vessel Does Have Trim Tabs. They Don't Seem To Help With This Problem. Any Advise Would Be Appreciated. I Have Every Owners Manual And Documents That Came New With This Boat And I Can't Find Anywhere What The Recommended Prop Is. Thanks
