Boat Drain
Franko
I have a Coba Hull # CBA65014M83A What size is It.<br />My real ? is There Is A pvc Pipe running down thru the middle of the boat under the floor.The floor was bad so we pulled up the plywood and found it .It does not drain .Is there somewhere to get plans to see where this goes.
muskyone
Master Chief Petty Officer
Re: Boat Drain
just a Guess but is it to run wires through
Jack Shellac
Re: Boat Drain
In center consoles, there's a 4-6 inch diameter tube to run wiring and cables through. This may be true for your Cobia, too. In some boats, there is a smaller tube right on the bottom of the boat that's intended as a drain from bow to stern.
