Boat doesn’t idles smooth. Is my Timing off?
FullSendMissles
I have a 1990 4.3 OMC Cobra V6 that idles really rough and back fires and occasionally stalls. I was thinking it could be the timing but not sure. What should I do?
Ayuh,..... Welcome Aboard,..... Could be ignition, but sounds like a carb issue to me,....
What's it's service history,..??
FullSendMissles
I have discovered a new problem. The boat no longer starts in idle. It will only start if I put the throttle up around 3/4 of the way. Then if I try to put it in idle it stalls. I tried adjusting the carb but it didn’t fix the issue.
Ayuh,..... Sounds like crud in the fuel system has gotten to the carb,.....
Did you service the points?
How did you clean the carb?
FullSendMissles
I took the carb apart and sprayed carb cleaner through the fuel and airways. I haven’t done anything to the points.
Lou C
You need cleaning tools and compressed air to properly clean a carb. Just spraying or soaking in carb cleaner isn’t near enough.
make sure every passage in the carb is clear with a fine wire or piece of fishing line
service your points, set dwell (with a meter) and then set timing
then adjust your idle speed
both these things effect your idle
Lou C
Is this a 2 bbl or 4 bbl, Rochester or Holley?
The points need regular maintenance, I usually replace mine every 4-5 seasons or when really pitted.
