helpmelovemyboat
- Apr 14, 2011
- 19
1987 OMC 3.0 Motor. Motor runs great at idle and when not in gear but dies when i try to put it in gear. I have checked the carb thinking maybe the accelerator pump was bad but it is fine. Next i checked the ESA switch and it works (stalls motor when pressed) but it stalls the motor for about 15 seconds and then the motor runs fine. This is too long of a stall however for the boat to go into gear... it just dies (but again when not in gear it will stumble for about 15 seconds and then run fine). I have a clymers manual and it shows an overstroke switch but someone has cut mine off. This is where it gets interesting however. I traced the wires back to the plug and there are two wires coming into the plug for the switch (black and blue) but four wires coming out of the plug (two blues fr the ESA switch and then two black wires for the overstroke switch. I thought that I had found the problem but the two black wires for the overstroke have no pins in the connector from the control box (it is made this way)...so even if i put a new overstroke switch on it wouldnt be connected to the ESA module in any way. This has me very frustrated. I ordered a new Overstroke switch today from a dealer but I am going to pull my boat down to him on friday when I pick the part up to show him the plug from the ESA module to see what he thinks. Also when the boat is in gear the esa switch is always depressed so there would have to be something to tell it to stop interrupting spark (hence overstroke switch) but like i said earlier the plug from the ESA module has no wires for the overstroke switch. I have read something about Mercruiser interupptig there spark for shifting some other way..any ideas?
