Re: Boat Dies out at High RPM
Usually when the high speed windings of a stator begin to fail, the RPM is limited, the motor will run up to A 2000 to 2500 and just hang there.
Test the stator voltage as spelled out in the FREE troubleshooting Guide available for downoad at CDIelectronics.com
Your problem is common, as previously pointed out by j_martin.
If your fuel PUMP is weak it will not provide enough fuel for much more than an a few seconds of throttle.
Also air leaking INTO the fuel lines, a restriction anywhere from the tank dip tube to the carbs.
Three tests.
Running
Squeeze the primer bulb firm and keep doing it while opening the throttle.
Install a clear hose between the pump and carbs, watch the fuel looking for any air bubbles indicating air sucking into the lines before the pump.
Cranking
Pull the fuel line to the carbs and watch the stream, it should be a strong pulsed flow, @ least 15 GPH or more, any less the engine will starve for fuel, bog and die.
