BOAT BOUNCES WHEN PLANED UP HELP
pwilson
I OWN A 88 BAYLINER TROPHY BASS BOAT.WHEN I TRIM MY BOAT UP, IT STARTS BOUNCING.I CALL IT POURPUSING.IT DOES NOT START UNTIL THE ENGINE IS ABOUT 3/4 OF THE WAY UP.THE MORE YOU TRIM THE BIGGER THE BOUNCE.THE ENGINE IS A FORCE 125.IT IS THE FACTORY ENGINE AND FACTORY MOUNT.I DON'T HAVE A JACKPLATE AND I DON'T KNOW IF IT HAS ALWAYS DONE THIS. I BOUGHT THE BOAT USED.MY BOAT IS ALSO 19'.PLEASE HELP :eek:
Jack Shellac
Re: BOAT BOUNCES WHEN PLANED UP HELP
Try shifting as much weight to the front as you can. When you get on plane, trim out until it starts porpoising and then trim in in small increments until it stops. Give the boat time to settle in between trim bumps. A little practice makes it easy to know where it's going to run best. Some folks eventually go to a 4-bladed prop if it's too bad and cant be corrected any other way.
Boatist
Pwilson<br />I agree with Jack, trim OUT until starts to hobby horse then IN until it stops and runs smooth. This is the best setting unless your are pulling a skier then I would trim IN more to jump on plane faster.
skiffer
Porpoising can also be caused by improper motor angle ie lower part of motor too close to transom. What happens is, as the bow of the boat rises the forward rake of the motor pushes the bow back down where it bounces off the water and the cycle repeats itself. Try tilting the motor back a little ie lower end away from transom.
spin-a-bait
if trimming it down does not help the only other solution is to apply more throttle,that usually works at least it does when I am driving.
