BallisticRenegade
- Aug 31, 2012
- 27
Currently I run two isolated batteries. One for the engine and accessories and one for the Trolling motor. I would like to modernize my systems a little which brings me to a few questions.
I have some dead space under the tip of my bow that I could stash a battery in. If I get a sealed battery can I strap a battery permanently under there? (it would be accessible for replacement if needed) If needed could I do it on its side if it is sealed? Battery recommendations? It is a 12V system.
If the bow does not work I have storage under the front deck of my boat. There is a label that states no fuel storage as it is not vented. Can I strap a battery down in there, it has the potential to be buried under life jackets and ropes.
Can I link the two batteries together to charge off of the motor? How do I go about this? It would be a long trunk (16 foot) I have a 1988 Johnson 90 HP doing the charging.
If it won't handle it or I cannot link them I would like to either put in a on board charger (recommendations?) or have a connection such as the trolling motor plug that goes to the battery that I can hook the charger up to so it can remain below deck or under the bow. would there be any problems with this?
Is there a monitoring system you would recommend to install to keep an eye on the two of them?
