Blue dot stains
STARR74
After I run my boat, I see little blue dots everywhere. They have stained the vinyl seats and even the white gel coat. I cant get them out of the seats and I cant seem to find out where theis is coming from. There is no leaking oil in the engine compartment or leaking oil on the outside where the lower unit is. I would appreciate any advice to help solve my problem. Thanks.
southkogs
Welcome aboard Starr.
Need a little more information: What type of setup (Outboard, I/O) and what model? Are you sure it's engine oil? Blue dots doesn't seem like it. Any photos?
STARR74
The boat is a 2007, 17 ft. Vectra 172 fish and ski. Has a 3.0 Mercruiser I/I.
Bob_VT
looks like oil....... I imagine a tiny leak that could be under pressure....... also check the vent's for the motor compartment - if oil gets in the vents it will also get out due to air pressure.
mike_i
Ensign
Where do the dots start? Do they start from a certain point or are they randomly scattered everywhere on the boat?
KJM
If you leave your boat in the water, could it be coming from a nearby boat?
Grub54891
If it’s on a stackable storage facility, it could be from a boat above you.
