Blows main fuse??
vtx03
Main fuse blows when neg.battery lead is connected? Mercury 75hp 2 stroke 2004
Tassie 1
G'day,
welcome etc
is this a new problem or a new motor to you?
Have you taken wires of the starter solenoid?
possibly not put them back on the correct terminal?
you need a wiring diagram if that is the case
also check that they are not rubbing on the block etc and shorting out somewhere,
GA_Boater
Welcome aboard.
The battery leads aren't crossed, are they. Wouldn't be the first time and it blows the fuse.
tblshur
vtx03 if that doesnt fix then disconnect rectifier and check hope this helps:joyous:
Bt Doctur
reversed battery cable will do this. With just the so called neg cable connected use a 16 or 14 Ga jumper from the positive side and remove the cable from the solenoid and touch the battery cable at the solenoid. There should be no spark.
