89 2.3 OMC Ford. Boat overheated to 225 degrees and I shut it down after I realized it has overheating. Fixed the overheating problem and now when I take it out and I try to give it some throttle I hear a knocking sound coming from engine. The boat puts out quite a bit of white smoke when I run it on the muffs. Did a compression check and all cyl are around 150 but #2 is only at 90. Does this sound like a blown head gasket? Thanks for any help.
