I have a 3.7 (4 cylinder) Mercruiser which blows oil out of the breather cap when more than half throttle, compression a little low in # 3 & timing mark off the scale. Is it likely for the timing to be the cause of all of this, or should I just pull the engine ??<br />The compression is 90, no oil in coolant, no PVC valve, engine runs great unless I time it according to the marks and a little hard starting unless dialed in just right
