I have an electrical issue. I have a 2006 195lr searay. I blew an ign fuse last weekend. I put a new one in immediately and when turned ign switch on it blew right away. let sit til next day, replaced fuse again, started and ran fine until it warmed up then blew again. I removed the gauge panel and found the purple wire that runs from the gauges to the engine compartment was reading ground. disconnect from gauge and it won't blow fuse but of course engine won't start either. Have no idea where to start. Could the ignition box be getting hot causing this or a sensor such as temp, oil. I have knowledge on 12v electrical systems but wanted to check to see if there were any shortcuts or obvious issues to start with. Also when engine is cold the same purple wire does not show ground. Don't know if it is ignition or warning sensors. Appreciate any help or ideas.
