We?re (Dad and I) having trouble with our 1988 Mercruiser 3.7 470 engine.
History With Our Engine
When we first got the boat a couple of weeks ago we did a compression test on the cylinders, the first three came back good at about 130 PSI each. Initially the forth cylinder read 0 PSI. We found a stuck valve, that bent a pushrod. We freed the valve and replaced the pushrod and turned the engine over by hand . The valve that was stuck was working up and down fine at that point. We did another compression test on the forth cylinder (where stuck valve was) and it went from 0 PSI to 50 PSI.
Today
We weren?t able to start the boat until today, because several things (impeller pump, fuel pump, etc?) needed to be fixed before the boat would run. Today we ran the engine for the first time. The engine is experiencing what appears to be blow-by. It comes out of the valve cover pretty strongly when the cap is removed and then out of the air cleaner (on top of carburetor) when the cap is placed back on the valve cover.
1. Does anyone know if this is an interference engine (pistons and valves can meet if their timing is off)?
2. Can this be caused by a sticking or poorly seating valve?
Thanks for the help
Today
Thanks for the help
