I have a 1986 Chris Craft sterndrive with the Mercruiser 3.0l ,140 hp engine. It was running fine until some preventative maintenance was performed. Opened the cooling system to replace thermostat. Found it in pieces. Retrieved as many as I could find.. Removed the intake/exhaust manifold and end plates looking for any other pieces. Reassembled all parts. When engine was running on muffs, was not getting same amount of flow through the prop. Took it to the lake for testing, and the engine was running at 210 degrees at slow speeds. Slowly motored back to the dock and hauled out. I am thinking that some parts of thermostat circulated into the block, thus causing the reduced flow at the prop. Any help and suggestions would be greatly appreciated.
