75omc302
- Jul 10, 2012
- 7
omc 302 1975motor, Freeze plugs popped, pulled motor up and replaced them. No cracks on outside of the block. cleaned out the fuel system, replaced coil and set points . put in the water primed it , fired up nicely. Spent about 10 minutes on the water and the motor loaded up and died. No hydralic lock happened. towed in and trailered . Checked oil and found vast amounts of water in oil. Figured the intake or head gaskets let go. pulled intake and valley was full of milk, valve train same, pulled heads, one side very wet with milk. Block is full of milk too !!!!!! compression check showed low or no comp in 1 thru 3, but 5 thru 8 was 120 psi or better. Now what ? cant find cause, or am not sure. dont want to do heads and intake to find out in the water it is in somethingelse !! HELP!!!!! @#*&@ cold wether !
:facepalm:
