Got a old boat I bought last summer that had a cracked block up and running this spring. Had to put another 165 straight 6 engine in it that I had kicking around. Had it professionally installed. and they put a new impeller in it while the drive was off. New gimbal etc etc. Had it on muffs a few times while I tuned it up and rebuilt the carb. It would come up to temp and stay even . Out on the lake tonight I ran it up to WOT after it warmed up. stayed ok for a while I noticed the temp ran up to around 190 Hotter than sitting in the drive way Idling. Had it going for a bout 15 minutes and when I looked down I noticed it was pretty hot over 200 then it went down quickly I figured a stuck Thermostat I turned around and headed back when it ran up again and then blew the hose and split it wide open. Steam, water and the whole mess. I was still out a 1/2 mile from dock. Had to have my son hold the hose together, lol and turn the bilge pump on and make tracks. I watched the temp thinking it might still be stuck but it never got hot again, maybe stuck open now? son said the water got warm but not hot. Got back ok besides son all wet, and loaded it up .
My guess is the thermostat stuck shut then blew the hose, would that be a good guess? Also I noticed on this engine after doing a search for hoses that there is some people doing a modification reversing the flow in the manifold is this a good thing to do?
Also Im having a bit of trouble finding the molded hose between the pump and thermostat housing. is it ok to use one of those " universal hoses on this application, or keep digging?
Thanks for your knowledge in advance
