Re: Bleeding oil automix system. Tohatsu 90hp
You can disconnect the hoses from where they go to the engine ports and let the engine run at an idle. When the oil starts coming out of the end you can reconnect them, but you normally would not develop an airlock. ( It could happen, but its rare) With premix it doesn't really matter if you have a momentary air lock. Once the system has purged though, your safe.
