I recently replaced a hyd line on trim unit--was unsure how to bleed system stopped by local marine shop and mechanic was kind enough to inform that this system should be self bleeding and all I needed to do was put oil in unit, raise it up allow it to sit for 30 seconds, lower unit and continue until running smoothly. I did this but this raised other concerns that I hope someone can help me with
1) He said my fill cap should have a dip stick--it didn't so I am unsure how much oil I should put in -- read earlier tonight that reservoir should be filled to top is this correct?
2) Not knowing how much oil to put in I only filled unit about 1/2 full when I tried to bleed system--while lowering unit I had oil (frothy obviously full of air) coming out of one line on each cyl--was wondering if this was normal and how it bleeds or is this a sign of something else--stopped bleeding system until I get answers
3) What is the knurled knob on unit that screws in and out and how do you know where it should be set
4)Should vent hole be open or have screw in it(saw you tube vid that had screw in vent hole)
Thanks for any input anyone has
