bleed tilt trim force 125
fisheymikey
I want to bleed the oil in the tilt trim I suspect some contamination.... creamy white
I did use 30 non detergent oil so want to flush it out
I remember some said remove one of the tubes then cycle up and down
which one?
mike
jerryjerry05
Re: bleed tilt trim force 125
The closest one.
Use a line wrench after you spray with PB Blaster for a day.
Then have someone in the boat and cycle the switch.
Then fill after it stops dripping.
Then repeat until it comes out clear.
Might take a while.
