bleed system check valve
dhughes49
I was checking over my tubing on motor when i lightly pulled on a bleed hose the pressed in check valve popped out . I just pushed it back in. Is this normal ? motor is 2002 150L carb model #0T514190
Faztbullet
Did the whole check valve pull out or just the nipple? If just the nipple did the white check ball and disk stay in place? I myself would replace it as these are swaged together and should not come apart.
dhughes49
Yes I think the brass nipple . I did not see the ball but I wasn’t looking for it . It is probably tiny . Is swaging in a new one difficult? Do I need a pro todo it for me ?
dhughes49
My bad you ment the part is swaged together. What’s the best way to dig out the half of the check valve?
