Well I think your good to go , snot perfect but that looks like a lot of used motors and I have seen way worse that was still running . If you cant feel the marks they cant be that bad . If the engine went ok last season and has reasonable compression Id let it pass . I think such marks are likely caused by a bit of carbon getting between piston and cyl and getting dragged up and down for a bit . I think if anything metalic( piston circlip of piece of broken ring or reed valve petal ) got in there damage would be worse
You could remove bits for further inspection but unless your planning on a rebuild if you find serious damage there is probly not much point , gotta admit tho, curiosity would see me wanting to pull the bypass covers as racerone says , relatively easily done .
Wipe the bores with a clean oily rag , chuck the heads on and do a comp test and if its OK try and forget what you saw and enjoy some boating. It aint that bad
