i have a used binnacle control that i just installed. I am wondering if it has a problem. I cant get it to shift into reverse without pushing the big square button next to the shifter. Is this normal? Every other boat i have used you could just push up for forward, then slide it back to neutral and reverse. It slides great into forward from neutral.. but if i try to slide it back to reverse from neutral it locks up until i push the button.. Anyone used this style control before,, the control cables are brand new and I wanted to make sure they were hooked up correct... shifts like butter
